Stevey2021's avatar
Stevey2021
Follower
Jun 03, 2021
GS728TP replacement /spare fan
Hello,
After almost seven years 24/7 the fans of the GS728TP switch are getting more and more noisy.
What are the right spare fan models and where can I buy them?
  • > What are the right spare fan models and where can I buy them?
       I have no idea.  I'd look at the actual fans, and then search this
    new Inter-Web thing to find suitable replacement parts.  Having a
    drop-in spare network switch can make this more convenient.
    > Model: GS728TP|ProSafe 24 ports PoE Smart switch with 8 PoE+ ports
       I don't use use "Smart" or PoE, so I haven't looked, but, for my simple
    unmanaged switches, I've avoided models with fans for a long time.
       In an emergency, I've managed to do some disassembly, cleaning, and
    insinuation of a drop of oil into the occasional dying fan.  It was much
    easier in the days of 5.25-inch fans, I'll admit.  Remarkably effective,
    in many cases, however, even for newer/smaller ones.
       Possibly a more appropriate venue:
          https://community.netgear.com/t5/x/bd-p/business-smart-plus-click-switches
    • pkgadd's avatar
      pkgadd
      Luminary
      Oil and fans are a difficult combination, you'll invariably create an oil aerosol liberally covering the insides of your device - as a result dust settles and creates a sticky matting over the internal components acting as a heat insulator (both damaging components, increasing fan noise trying to counteract and becoming a fire hazard).
      Replacing the fans is usually the only real option, but I doubt these are considered to be (officially-) user-servicable, so documentating might be lacking.
      • antinode's avatar
        antinode
        Guru
        > oil aerosol liberally covering the insides of your device [...]
           "invariably"?  Strange, then, that I've never observed "a drop of
        oil" "liberally covering" anything, any place.  Do you believe that fan
        manufacturers don't use lubricants?  Read it again.  I didn't (and
        wouldn't) recommend immersing the fan _blades_ in oil.
