oszy
Oct 01, 2021Aspirant
Guest Access 2.4ghz Enabled but not visible since new firmware
This week I installed firmware version V1.0.2.84 (the most recent). Since than my guest access 2.4ghz is still enabled but not visible (so neither accessable) on android nor apple devices. I've had ...
oszy
microchip8 wrote:Roll back the firmware?
Latest one has multiple issue and it seems the further we go, the more broken the firmware for the R7800 gets.
Thank you for your answer,
Is there an easy way to do this?
microchip8
Oct 01, 2021Master
Sure. Use a wired PC and go to http://routerlogin.net or http://192.168.1.1 then flash a version from here: https://www.netgear.com/support/product/r7800.aspx#download (click on the + sign for other versions)
