texasTrio
Apr 18, 2017Aspirant
guest access as secondary router
This is my first post, my first netgear router and my first day using the routher. I have been a lifelong linksys consumer. I have the AC1900 R7300 (yes, not R7000, it is the R7300 that came with DS...
- Apr 19, 2017
thanks, was trying to figure out why guest access was not settable.
michaelkenward
Apr 19, 2017Guru - Experienced User
texasTrio wrote:I thought maybe to connect with ethernet, disable Access Point AP, see if I can turn off the guest sharing, etc. Any ideas?
I'm not sure that I understand what you are trying to do, but if you don't have it already, the manual for the R7300 is here:
>>>>> R7300DST | Product | Support | NETGEAR <<<<<
There are plenty of entries for guest access.
- texasTrioApr 19, 2017Aspirant
