texasTrio
Apr 18, 2017Aspirant
guest access as secondary router
This is my first post, my first netgear router and my first day using the routher. I have been a lifelong linksys consumer. I have the AC1900 R7300 (yes, not R7000, it is the R7300 that came with DS...
- Apr 19, 2017
thanks, was trying to figure out why guest access was not settable.
TheEther
Apr 19, 2017Guru
In order for an AP to provide isolated guest access some means is required to isolate the traffic while it traverses the Ethernet line to the primary router. Typically, this is done using VLANs and must be set up on both the primary router and the AP. Well, most consumer grade routers don't provide this type of VLAN support. Full-fledged VLAN support is usually only found on SOHO/Business-class gear.
The easiest solution is to upgrade your primary router to one with guest access. There are affordable SOHO/Business-class as well as third-party solutions but they are less user-friendly.
texasTrio
Apr 19, 2017Aspirant
Thanks, that is what I suspected. I am going to put another of the same router is primary.
