AT007
Jun 24, 2022Aspirant
Guest Network Isolation: Nighthawk R8000
My Setup is Nighthawk R8000 --- TP-Link RE205 AC750 Universal Wireless Dual Band Range Extender Both devices are running the latest Firmware as of 23 June 2022. I have 2 networks: Main 5GHZ ...
AT007
I doubt that ... as Client isolation works from NG... not tplink...
Jun 24, 2022Guru - Experienced User
Problem is that most extenders work by assigning a virtual mac address to devices connecting to the extender.
And if everything works as it should when running through the router, I'd be looking closer at the extender.
