perseid's avatar
perseid
Guest Network issue
Hi all, when enabling the Guest Network, the Guest SSID is visible and devices are able to connect properly, but the problem is that the connection is not stable, it suffers frequent interruptions. Those same devices are able to connect to the router's main network and connection is very stable (no interruptions). Any suggestions to make the Guest Network work properly? Thanks
(Running latest 1.0.2.20 firmware in Nighthawk R7800 X4S AC2600 Router)
  • perseid wrote:
    StephenB wrote:
    perseid wrote:
    Maybe it has conflicts when it finds same SSID from a neighbor?
    That was what I was thinking.
    I'm almost sure that this is not the issue since I haven't seen any SSID name like that in my neighborhood, but I will try a custom name just to discard this possibility. Will report back, thanks.
    I tested the Guest network with a custom SSID and apparently the connection is stable now. Seems that the SSID name was the culprit. WIll let the testing a few more days and if stable will mark your reply as the solution. Thanks.
  • Start by changing the channel. Is it on both bands on guest network? I don't think that there's something more you can do aside from changing the channel and using a different firmware.
    • StephenB's avatar
      It's worth a try, but the channels used for guest are the same ones that are used on the (stable) main network.
      Is this happening in both bands?  Is the SSID being broadcast?
      • perseid's avatar
        perseid
        Thanks for your replies. Yes, as Stephen says I assume that the Guest network picks up the same settings as those used for the main (stable) network, so nothing changed there. Yes, the SSID is being broadcast in the Guest network, and the issue is happening in both bands (2.4 and 5).
