ns8
Jan 07, 2018Tutor
Guest network password--nothing works
Hi Netgear! I'm trying to enable my guest network. Nothing I enter into the password field is accepted as a password and I get the message telling me about the "8 to 63 ASCII or 64 hex digits." T...
- Jan 07, 2018Did you set up passwords for both guest networks (2.4 GHz and 5 GHz)?
TheEther
Jan 07, 2018Guru
ns8
Jan 07, 2018Tutor
A-ha!
So the frame scroll bar on the right didn't show up. Not sure if this is because of Safari or MacOS, or the webserver on the router, but after I started to TRY to scroll up, then the scroll bar appeared.
You can see it missing in the image I attached in the thread opener. So I'll try that.
