Batman-15's avatar
Jul 02, 2021
Guest Network Technical Explanation
 I currently have my R6900P router configured with both 2G/5G LANs as well as 2G-Guest/5G-Guest LANs. I use the 2G/5G guest LANs for my IOT devices such as treadmill, lights and for any friends that want to connect while they are here in my house. I've also configured MAC authentication and enabled the computers cannot see each other option. My question is, are the Netgear guest networks simply a VLAN? What type of security do they offer?I have been trying to find some in-depth technical documentation that explains how Netgear has implemented their guest networks.
Much gratitude in advance for any and all responses.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    The guest network still works off the current bands that are being broadcasted but is Isolated via the firmware in the router from the main networks.
    DarrenM
    • Batman-15's avatar
      Batman-15
      Tutor
      Thank for your response. Are there any technical documents that explain how this is separated in firmware?
      • microchip8's avatar
        microchip8
        Master
        Not that I know of, but Guest network is a bunch of Linux iptables rules to separate it. There's no VLANs involved
