Luann2
May 03, 2023Initiate
Guest network
I’m trying to set up the guest network but I get an error. The router could not apply your new settings. Check Wi-Fi connection and try again. I’m definitely on Wi-Fi so what could be wrong.
Luann2
R7450 ac2600
michaelkenward
May 04, 2023Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
