Odi
Mar 25, 2016Aspirant
Guest WiFi network much slower than normal network
Speedtests from a device connected to the guest network 5GHz WiFi are much slower than when the same device is connected to the normal 5GHz WiFi. I reproducibly measured around 7ms 18/10 Mbps up/dow...
- Retired_MemberMar 26, 2016
that version was pulled and pulling FW rarely happens...revert to previously working FW
Retired_Member
Mar 26, 2016that version was pulled and pulling FW rarely happens...revert to previously working FW
- OdiMar 26, 2016Aspirant
Thanks a lot. Downgrading to V1.0.4.30_1.1.67 solved the problem. Now both the normal WiFi and the guest WiFi have similar speeds again.
