H12Mike
Jan 19, 2022Aspirant
Guest wifi not showing on my bbq guruu
I have a fan controller for my bbq. It is connected to my wifi. But I need a 2.4 connection but the controller only recognizes the 5.0 and this causes connectivity issues with the controller. I set up the guest wifi at 2.4 but it does not see it. Any ideas. By the way I have a wired Ubiquiti access point only 10 feet from the controller.
What model bbq guru do you have? I have one of the higher end models and its 2.4ghz only.
You have the RAX120?
Usually when you setup the bbq guru, you go through setup on your phone. You need to make sure you phone is connected to the 2.4ghz for setup.
- H12MikeAspirant
I have the ultraQ. I can see the guest wifi on the iPad and sign in to it. But the guest wifi does not show on the UltraQ as an option only my main wifi shows.
I'm not sure what you have going on with your setup. The ultraq is only a 2.4ghz device according to its manuals spec page where they have to declare that info.
So it sees the standard network on the router but not the guest. Why not connect to the guest?
Also, make sure to disable wpa3 on the router. I've seen a lot of IoT devices like those not work with wpa3
