Smokinquack89
Aug 19, 2018Tutor
Hacked and locked out of my R7000
Hello all, I feel I was hacked or something went on vacation and came home unable to connect to my router. The ssid seems to be changed and the password doesn't work now. I tried to the router passwo...
- Aug 19, 2018
First make sure you don't have CAPS on if there are no caps on your password for the router.
Otherwise do the Factory Reset using the depressed button in the back. That should get you back to the cleared state with the old UID and PW.
Is it possible your router is OFF and you are seeing another one or are you hardwired to it?
Possible it is damaged too, what color are the LED lights?
IrvSp
Aug 19, 2018Master
Smokinquack89
Aug 19, 2018Tutor
So.... I did see that reset button when I first started troubleshooting then got so frustrated with the support that I completely forgot about or wrote it off as it just rebooted the unit. Based on the support they made it seem as there was a more serious issue. And what do you know I submit a problem a solution is brought to my attention 10 min later. I reset my router reconfigured everything and I am good to go kudos to you! Man I'm over the moon did not realize the reset button took back to factory settings.LOL
