jdistefa
Jul 27, 2022Aspirant
Hard wired windows 8.1 computer can't connect to internet through r6900 router- advice appreciated
I recently had to reset my modem and r6900 router. After a router factory reset I was able to connect the majority of my computers to the router and internet. It is using firmware V1.0.2.26_10.0.45. ...
- Jul 29, 2022
It turns out that the problem was hardware related after all. After I replaced the modem and router, AND bypassed the currently installed ethernet port with a usb-ethernet adapted I was able to get back on the internet using the ethernet connection. Thank you all so much for your help!!! The driver update suggestion got me thinking about the ethernet port which lead me to try and bypass the existing port which solved the problem. I definitely appreciate the suggestion! This problem lead me to upgrade my network hardware (router/modem) and scan all of my computers for viruses (some found and removed) so it all turned out well in the end. Thank you!
jdistefa
Update- now another computer can't access internet. Also, the modem is a Arris surfboard sb8200. And the dns is set to automatic, ip also set to auto. The ISP is comcast with a cable connection. We are using CAT 6 and 7 cables. Thank you!
