TWISK
Oct 28, 2022Follower
Harman Kardon citation one cant connect w netgear R7000
INSTALLING HK CiTATION ONE W GOOGLE HOME HK CANNOT FIND ROUTER. (PASSWORD RESET STILL NO CLUE)
Oct 29, 2022Guru - Experienced User
1. what firmware is on the r7000?
2. what modem/gateway is the router connected to?
3. what error/issue do you get when you try to connect the HK? (the more detail, the better we can help)
4. did you try contacting HK for help setting up their device?
