kimisdad
Dec 06, 2021Follower
Have AX70 wifi works lan connect to netgear 16 port unmanaged switch or 8 port does not connect.
Have Nighthawk AX70 wifi works lan connect to netgear 16 port unmanaged switch or 8 port does take down internet. Single wired pc works however my entire lan network of 10 devices when connect to Net...
michaelkenward
Dec 07, 2021Guru - Experienced User
It is hard to understand what that is saying.
Something to do with a switch on your network knocking you off the Internet?
What router is this? (AX70 isn't a model number.) RAX70?
What is the modem, if there is one, between the router and the Internet?
Where is this switch on the network?
If you do have something like the RAX70, you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
