postman38501
Feb 17, 2022Follower
have to continually reset nighthawk ac 1750
I have to daily reset the router to reconnect to the extenders, one is 15 feet from the router and the other is 20 feet from the router. all 3 are running current on updates. most of the problem is ...
Feb 17, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender (EA and EAX Series) products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
