Rolo2020's avatar
Rolo2020
HAving a hard time to access my router from workplace
I receantly bought the Nighthawk R6700 for my home network and I'm trying to do something as simple as allowing remote access to the router from my workplace. I followed the directions by a) enabl...
  • Rolo2020's avatar
    Sep 24, 2020
    Well... aparently the issue got solved after I performed a reset to restore factory default settings.
