SMN11111
Aug 30, 2021Aspirant
Having micro-breaks while connected with wire
Hi! As the titels says, im having micro-breaks with the wired connection to my pc. I dont notice this while on wifi or otherwise while surfin online. Only time I notice it is while playing (csgo...
Aug 30, 2021Guru - Experienced User
Whats on the other end of that ethernet cable?
Basically whats controlling your internet connection.
https://kb.netgear.com/30186/What-is-Double-NAT
- SMN11111Aug 30, 2021Aspirant
Hi plemans,
Are you reffering to my router? In that case its a netgear AC750 model no:R6020 and the router is connected directly to the wall to my internet provider so I dont have a modem.
Edit: I can also add that Ive been monitoring my network ping with ping.canbeuseful.com and it has yet not noticed any "fails" but I do get some high ping spikes, anywhare between 100-540 ms. Can this maybe be the issue since this kind of ping will probably trigger lag ingame?
- plemansAug 30, 2021Guru - Experienced User
Many apartments that bundle internet with, have their own router/switch running. when you add your own router to it, it causes a double nat.
that can cause lag/issues when you're cascading multiple routers.
Thanks but I dont think this will help me. We dont have any other router/switch, I have fiber and my outlet is connected to the city network and to my provider and the router is connected directly to the fiberoutlet.
