hlb512
Jan 24, 2021Aspirant
Having trouble updating firmware on the router
Hello. I have the nighthawk R6230 and keep getting emails that there is a firmware update I need. I have been unable to update it. I got the app and followed the instructions but once I get to the pa...
michaelkenward
Jan 25, 2021Guru - Experienced User
This is the most reliable, and preferred, way to update firmware.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Or read the manual for other options.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have software and firmware for your device.
Check the section in the manual on updating the firmware.
You may have done this already. I can't tell from your message.
