Martin1234
Nov 17, 2015Tutor
Help - Nighthawk R7000 fails to provide gibabit speed
Hi Until recently my R7000 provided lan speeds of 1Gbps but now is only running at 100Mbps. I have not made any changes to it and this is for cable and wifi connections. My ISP (VirginMedia) is prov...
- Nov 17, 2015
What does the router report as your port speeds for your LAN ports to your laptop and desktop?
It all depends on your latop's NIC card, its respective drivers and the cable type. Do not use CAT5 ETherent. It will only give 100Mbps.. Use CAT5e or better.
Martin1234
Nov 17, 2015Tutor
If I plug the cable from my modem directly into my PC I can get the correct speed from my ISP of 200Mbps but if it goes via the R7000 it is reduced to a 100Mbps connection and about 94Mbps speed. This was all working fine until about 2 weeks ago. Its not PC specific because I get the same issue on desktop and laptop alike.
Ah... I was using both laptop and desktop on wired connections (not the same one), have just tried my laptop on WiFi and get a 300Mbps port speed to the router and an internet speed of 200Mbps which is what it should be. So the problem is only on a wired LAN connection via the R7000 as wired dirrect from the modem is fine. Is there any setting in the R7000 that could be slowing down the port speed?
netwrks
Nov 17, 2015Master
- Martin1234Nov 17, 2015Tutor
Hi
All the cables are rated Cat5e - this was all working fine two weeks ago and nothing has been changed since then.
Where in the router will I find the port speeds for the connected devices?
thanks
Martin
- rpoffenNov 17, 2015Virtuoso
The easiest thing to look at are the LAN port status lights on the router. If they are amber, it is 100Mbps, if it is white it is 1 Gpbs
