benthekul
Feb 13, 2021Guide
HELP | R7000 Router Cutting out
Recently, my nighthawk R7000 router has been having frequent cut outs in the internet. I have tried every solution I found online, from changing my DNS servers to more advance means. The problem orig...
- Feb 15, 2021It was released in 2013 so it's actually going on 8 years old.
One option for people is there's a ton of 3rd party firmware for the r7000 if you do a little looking. You won't find it on the official forums though
benthekul
Feb 14, 2021Guide
I am on the latest firmware that being V1.0.11.116_10.2.100. I am connected to a Cablevision/Optimum Modem. The model for that is Arris TM1602 Docsis 3. And it happens to all devices.
R7000
cjmorris
Feb 15, 2021Aspirant
I am having this same issue. Router lights just cut out. Router power light is orange and the Ethernet # I am using is also orange. I’ve already called my ISP 3 times and they said they don’t see anything on their end. It had to be the router but I can’t figure out a fix. Any help appreciated.
