benthekul
Feb 13, 2021Guide
HELP | R7000 Router Cutting out
Recently, my nighthawk R7000 router has been having frequent cut outs in the internet. I have tried every solution I found online, from changing my DNS servers to more advance means. The problem orig...
- Feb 15, 2021It was released in 2013 so it's actually going on 8 years old.
One option for people is there's a ton of 3rd party firmware for the r7000 if you do a little looking. You won't find it on the official forums though
benthekul
Feb 15, 2021Guide
cjmorris Its unfortunate but it is a very popular router. Its showing its age at over five years old and Netgear could care less. Its only updates are for security really.
cjmorris wrote:
I feel like reverting back to firmware’s is going down a rabbit hole. This many people with the same router shouldn’t be having the same issue. I have no other option but to just buy a different router.
Feb 15, 2021Guru - Experienced User
- benthekulFeb 16, 2021Guide
One option for people is there's a ton of 3rd party firmware for the r7000 if you do a little looking. You won't find it on the official forums thoughI just assumed considering my model's production date. I ended up doing just that with that by using a third party firwmare. It resolved my problems and I don't care about the warranty or repair considering if it does break (hardware-wise) ill just buy another router. In fact, do you have any recommendations for a router that could be an upgrade?
R7000- plemansFeb 16, 2021Guru - Experienced User
I'm a fan of the R7800 but its an AC device and not AX. If you've got the R7000 back and running well, I'd hold off for a period for gen. 2 of AX routers. The first generation of a new spec is always a bit shaddy.
plemans wrote:I'm a fan of the R7800 but its an AC device and not AX. If you've got the R7000 back and running well, I'd hold off for a period for gen. 2 of AX routers. The first generation of a new spec is always a bit shaddy.
Is the gaming-line, the ones with dumaOS worth spending the extra money on? Heard its good though.
