BoroDeke
Apr 09, 2019Aspirant
Help a Noob Out? Trouble with 5G
Hey there - I was hoping someone in this group might be able to help me out. I'm a noob, for sure, so I appreciate very much any ideas someone has.
I have a R7000, along with an MB8600 modem. I...
- Apr 09, 2019
Follow instructions here, https://kb.netgear.com/000060253/R7000-Firmware-Version-1-0-9-42.
I'd suggest also RESETTING the router using the RESET button on the back after updating and entering ALL your settings required MANUALLY, but you can test it first to see if OK. If not, do the RESET. Consult manual how to do that or Google for it.
BoroDeke
How do i do that? Is there something pinned on here that explains how? And thanks.
IrvSp
Apr 09, 2019Master
- BoroDekeApr 09, 2019Aspirant
thanks! Much obliged
