iiKZMA
Aug 09, 2021Aspirant
HELP! Dos Ack Scan / UDP scan
Hello, all of this has been happening as of yesterday. Do i need to be worried? [DHCP IP: (192.168.1.8)] to MAC address EC:08:6B:1E:1F:C2 Monday, August 09,2021 17:21:22 [UPnP set event:AddPortMapp...
microchip8
Aug 09, 2021Master
NETGEAR is famously in producing 98-99% of false positives. If this bothers you, disable DoS logging. If that doesn't work disable completely DoS protection. I run 4+ years without DoS protection and didn't have any issues
iiKZMA
Aug 10, 2021Aspirant
I've seen that. But is i troublesome that its all different ip addresses sending DoS Attack and ACK Scans. There was also a TCP Port scan, i dont know if thats someone attacking me directly
