scamperpamela
Jul 16, 2021Star
Help in choosing a new router for 35+ device home network
My home network I think has outgrown itself! From just a few devices I am now at over 35 devices - at least 8 computers, phones, rokus, 4 extenders, lots of Ring devices, etc. While there are only t...
Jul 17, 2021Guru - Experienced User
Usually when people are using more than 1 extender, I highly encourage them to move to an actual mesh system like netgear Orbi.
If you're needing 2x extenders and 2x-AP's, when you look at mesh systems, i'd look closely at the tribands. Their option of using both dedicated wired backhaul and a wireless backhaul will offer much better stability, speeds, and lower latency.
Plus thne you can add satellites as needed for addional coverage.
scamperpamela
Jul 17, 2021Star
Thank you for your expertise! Just looking at Netgear products was pretty confusing even though I have a computing background (but not wifi expert), and I appreciate the help.
Are you thinking AC3000 or AX3000? Would I have to toss the current extenders I own?
I am assuming you can set up the satellites for wireless or wired?
I don't mind spending the money but of course don't want more than I need. It it unlikely we will expand much beyond what we have now.
- plemansJul 19, 2021Guru - Experienced User
Which version would you need? I tend to over engineer because even though you think you'll have plenty for what you're doing, something always changes or needs more speed or..... so better to have a little more than what you need versus just enough.
Your extenders/ap's can be used but it won't integrate with orbi. so whether you use them or not, would just be personal preference. Or if you wanted a backup network or even a network to put things like IoT devices (smart switches, etc) on.
And orbi can use both wired and/or wireless backhaul. I've got a mixture of them setup at any given time at my home.
- scamperpamelaJul 19, 2021StarI'm a retired computing professional, so I understand what you say about over engineering - I do the same thing with computer purchases, backup strategy, etc.I just spent 4 hard months getting a Ring setup I like and studying router and device issues and am over it for the moment. I think what I will do based on your advice and my fatigue is wait until I'm in the mood for it or until network performance is so consistently bad I can't stand it (it is now occasionally bad and probably getting worse!). It is possible I can fine tune Ring to not be as big a hog and prolong the current system, but I doubt it!When I switch to a new system, I will probably buy the latest high end home Orbi system according to your thoughts on the subject and set aside my current system. One reason to buy the high end system is not having to set up another system anytime soon. I suppose I could sell some of my other gear on ebay, etc.I was not happy with the nighthawk I had because it died in 13 months and was costly. How is the reliability of the Orbi, do you happen to know? I like to keep a spare router around since it is a bit of an emergency if the router dies, but that doesn't seem practical at the cost of the Orbi.
