wjmorrell32
Jul 15, 2021Aspirant
Help me troubleshoot my C7000v2
I have been experiencing issues over the past couple of days where my internet drops periodically throughout the day. Sometimes I need to reboot my modem/router othertimes it comes back online on its...
wjmorrell32
Jul 16, 2021Aspirant
I've attached some screenshots of different things. Note - the internet was running perfectly fine when I took these screenshots, I can take more screenshots the next time the internet loses signal.
Jul 16, 2021Guru - Experienced User
Event logs help more than logs. Event logs show the modem side.
but you have a bunch of errors in your line.
Remove any splitters, amplifiers, or signal attenuators in your line.
check the line for kinks, damage, bad/old/corroded/cheap connectors and remove them.
Preferably, move the C7000 to right where the coax comes into the home to prevent wiring internal to the home being the issue.
- wjmorrell32Jul 16, 2021Aspirant
plemans I appreciate all the information you're giving me. I live in an apartment building that was once 3 seperate units and now is converted to 1 single unit. So there are a bunch of splitters and amplifiers in the basement with atleast 15 different coax ports. If only they were labeled so I could unplug all the ones that arent in use. Anyhow, I've attached the event logs, I suppose there may be some other information in there.
Internet just crashed again - here is what the upstream / downstream looked like when it went out.
- plemansJul 16, 2021Guru - Experienced User
You have signal issues.
Move the C7000 to right where the coax enters the home and connect it there.
If everything works out, then you're going to have to clean up the coax lines running to where you want the modem. (they make cheap coax line testers)
Every splitter reduces the signal and gives a chance for a bad splitter and can cause errors.
A direct connection is best.
but if you need one for tv, then you use a double splitter with one leg going to the modem and the reset splitting off the the tv's.
You want the modem getting the best signal possible.
