ashleyxxa
Dec 08, 2020Guide
Help! My Nighthawk R7000 has more packet loss than my cheaper wifi router.
I have been trying to play Shadow PC with my Nighthawk R7000 thinking it would be an upgrade to my Honor Router 3 but I was shocked to see that the Nighthawk R7000 which is twice the price has so muc...
- Dec 14, 2020
Thank you Plemens, I have had to look things up so it took me a moment to get around to it.
1. The gateway is https://kabel.vodafone.de/static/media/Arris_VodafoneStation_TG344DE.pdf it's in German so if there are specifics you need to know let me know and I can look them up.\
2. RE: Firmware, I will try a. firmware update. When you say hardwire do you mean that I do it through hardwire from laptop to router?
Dec 08, 2020Guru - Experienced User
What modem/gateway is it connected to?
What firmware is on the R7000? That's kind of key as the r7000 isn't known for the best firmware.
I usually recommend anytime you c hange firmware with the r7000 to do it over a hardwired connection and then do a factory reset and a clean install afterwards.
- ashleyxxaDec 08, 2020Guide
Hi Plemens! Thanks for replying this is bringing me no end of frustration.
My modem is the factory default provided by vodafone. I'm not sure what it is. All I have to go on is logically A/B testing two different routers through the same modem with widly different results points to the Nighthawk underperforming. Also, there are no other devices connected to the network when testing.
I should also note this is going through my Macbook over 5ghz. The surprising thing is that a speedtest.net will give nearly identical results of 250 mbps on both the R7000 and Honor 3.
Re: FirmwareThis is what I have V1.0.9.88_10.2.88. I havent done any updates or changes.
Which firmware do you reccomend?
When you say do over hardwired connected do you mean connecting to the router via ethernet and then doing a firmware update? Then I hit factory reset button on the back. What do you mean by clean install? Do you mean erasing the router from my computers local memory?
Thanks!- plemansDec 09, 2020Guru - Experienced User
A couple things.
1. The gateway is important as combo devices can cause a double nat. Some routers handle it better than others. So what actual gateway model is it?
2. the firmware you're on is not the latest or even the agreed upon most stable.
The latest is 1.0.11.110. and the agreed upon stable version for the r7000 is 1.0.9.42
if you change firmware, make sure to do it over a hardwired connection, factory reset after the change and do a clean install. By clean i mean don't use a backup configuration.
- ashleyxxaDec 14, 2020Guide
