ashleyxxa
Dec 08, 2020Guide
Help! My Nighthawk R7000 has more packet loss than my cheaper wifi router.
I have been trying to play Shadow PC with my Nighthawk R7000 thinking it would be an upgrade to my Honor Router 3 but I was shocked to see that the Nighthawk R7000 which is twice the price has so muc...
- Dec 14, 2020
Thank you Plemens, I have had to look things up so it took me a moment to get around to it.
1. The gateway is https://kabel.vodafone.de/static/media/Arris_VodafoneStation_TG344DE.pdf it's in German so if there are specifics you need to know let me know and I can look them up.\
2. RE: Firmware, I will try a. firmware update. When you say hardwire do you mean that I do it through hardwire from laptop to router?
Dec 09, 2020Guru - Experienced User
A couple things.
1. The gateway is important as combo devices can cause a double nat. Some routers handle it better than others. So what actual gateway model is it?
2. the firmware you're on is not the latest or even the agreed upon most stable.
The latest is 1.0.11.110. and the agreed upon stable version for the r7000 is 1.0.9.42
if you change firmware, make sure to do it over a hardwired connection, factory reset after the change and do a clean install. By clean i mean don't use a backup configuration.
ashleyxxa
Dec 14, 2020Guide
I was able to fix the issue with a firmeware update to the latest and a factory reset. Thank you Plemens! The oddest thing is that the router said with the old firmware that it was up to date. I guess I'll never trust that again!
- Portwey84Dec 29, 2020Virtuoso
ashleyxxa wrote:I was able to fix the issue with a firmeware update to the latest and a factory reset. Thank you Plemens! The oddest thing is that the router said with the old firmware that it was up to date. I guess I'll never trust that again!
I've done no less than 4 firmware updates to my R7000 this year alone, each one quite successfully I might add. Each and every time before the firmware update, upon scanning my router through the browser GUI or the Nighthawk App, it said there was no firmware update available, so yes, you're absolutely right not to trust the 'check for updates' button. I now check the Netgear download page at least once a month just to see if there are any further updates.
I've been on v.110 since its release, again, just like the previous firmware updates I was on, I had zero issues, they've all worked flawlessly on my router.
