roundkick's avatar
roundkick
Initiate
Jan 23, 2018
Help? R7000 not showing network in wifi options.
I disconnected my modem and router this morning to move furniture.  Now my modem is working but the nighthawk router is not working. I have two white lights on.  I have resert the modem and router NU...
  • antinode's avatar
    antinode
    Jan 02, 2020
    > [...] tape a coin over it. [...]
       Because pressing on "a coin over it" won't press on _it_?  Or has
    your coin a suitable hole in it?
       I'd try taping a bottle-cap over the button, rather than glue or
    disassembly and other damage.
