ksw210
Mar 29, 2016Aspirant
[Help] r7000 router 5Ghz light (LED) not lit out on the router
Hey guys, my r7000 router 5Ghz light is out on the router
It show 5Ghz is enabling in Netgear genie, and i'm not able to search it in wifi... is it software / hardware problem.... i gotta ne...
- Mar 29, 2016
Try a reset and flash the firmware again. There is a beta out right now.
ksw210
do u meant V1.0.6.40_1.1.90? Sure! I will try it out later.
hope it works
Wolf_666
Mar 29, 2016Luminary
Yes, I am using it and it works fine.
- ksw210Mar 29, 2016Aspirant
U had same issue as well?
- Wolf_666Mar 29, 2016Luminary
I did not ever have any problem with my R7000, both with stock firmare and DD-WRT. Now I only use stock FW because it is more reliable on Wi-Fi performance and because I use my R7000 as an AP only.
Man i made it.
1) upgraded Firmware
2) restored to default setting
Works for me, Appreicate for the reply :)
