YoshiKatzo
Sep 17, 2019Aspirant
Help!! R7000 Router Won't Connect To Modem Since RESET
Hi there, I have purchased a R7000 Nighthawk router and it was working perfectly fine! I messed with heaps of settings and was having loads of fun with it, however, I wanted to reset all my setting...
- Sep 27, 2019
My ISP required me to either kick my connection before I change routers or wait 30 minutes for the lease to expire. The way they determine a change in router is through the MAC adress. Why dont you clone the MAC adress of your Netcomm to your Netgear?
Im guessing you can acess the router just fine with it connected directly to your PC. From what you have written then every configuration setting to acess the network is also fine.
This leaves me to suspect that theyre employing some sort of block.
YoshiKatzo
Sep 25, 2019Aspirant
Also, I can still see NETGEAR73 available on wifi devices on my phone?? Even though the router (R7000) is currently unplugged? Is this normal? or does it have anything to do with my issue?
YoshiKatzo
I have just connected my R7000 to my ISP provided Router! Using a ethernet port on my ISP Router and directly into my R7000 Internet port and it seems to be working this way...
But I don't want two routers haha, any suggestions??
- YoshiKatzoSep 25, 2019Aspirant
Would a Static IP from my ISP resolve this issue?
- YoshiKatzoSep 26, 2019Aspirant
ANY HELP??
