sd8951
Jun 10, 2021Follower
Help Reset ROUTER password on AC1200
I found another question with the same problem. I don't know if it helped them but I still can't figure out how to reset my router password. Not the password to the site. I typed in the login url AND the 192... hit cancel and it gave me the sign in again. The manual says it will prompt me (after CANCEL) for the SIN. It didn't. I'm not an idiot. I would just like to reset my router to another password.
Thanks
1 Reply
"AC1200" is a speed, not a model number. Look for "Model" on the
product label.> I found another question with the same problem. [...]
Thanks for the helpful link.
> [...] I still can't figure out how to reset my router password. [...]
_Which_ "router password"?
> [...] The manual says [...]
_Which_ "The manual"?
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for "Types of Logins" and "Reset". Further reading might not hurt,
either.
> [...] I'm not an idiot. [...]If you say so, but you don't seem to have found your router's model
number or its User Manual on your own.
https://en.wikipedia.org/wiki/Dunning%E2%80%93Kruger_effect> [...] I would just like to reset my router to another password.
If the password recovery scheme doesn't work (or doesn't apply to
your model and firmware), then you may need to reset everything else,
too.
