Auswi7797
Oct 21, 2020Follower
Help setting up DM200 and MR60 Mesh
Hello I am using Fibre to the Node Broadband and need help setting up my home network. I want to use the DM200 to receive the internet then pass it through the Mesh MR60 router plus its 2 satellite...
- Oct 21, 2020
The MR60 is a more capable device.
I'd setup the DM200 in modem only mode (disable its router functions) and run the MR60 in router mode.
Oct 21, 2020Guru - Experienced User
antinode
Oct 21, 2020Guru
> Do I leave DHCP on in the DM200 [...]
DHCP is not the critical thing.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Disable the
Modem's Routing Features and Use the Modem as a DSL Modem Only".
