Auswi7797
Oct 21, 2020Follower
Help setting up DM200 and MR60 Mesh
Hello I am using Fibre to the Node Broadband and need help setting up my home network. I want to use the DM200 to receive the internet then pass it through the Mesh MR60 router plus its 2 satellite...
- Oct 21, 2020
The MR60 is a more capable device.
I'd setup the DM200 in modem only mode (disable its router functions) and run the MR60 in router mode.
michaelkenward
Oct 22, 2020Guru - Experienced User
That's the way to do it.
I chip in simply to provide some feedback as a DM200 user. In modem only mode, the DM200 is hard to get at. (No obviously accessible IP address on the local network.) So update the firmware before you bite the bullet. And create a backup of your settings, just in case you need it later.
The manual for the DM200 explains the implications of accessing the thing in modem mode, but with luck you won't need to get into it.
antinode
Oct 22, 2020Guru
> [...] In modem only mode, the DM200 is hard to get at. (No obviously
> accessible IP address on the local network.) [...]
Do you mean that the "IMPORTANT:" suggestion in the User Manual does
_not_ work?
You can now access the modem only through a fixed IP address,
which is 192.168.5.1.
It doesn't _look_ complicated.
> thing in modem mode, [...]
"implications"?
