waxensens
May 16, 2022Aspirant
Help to get the most out of my Netgear Nighthawk.
My old router is beyond repair and I picked up the Netgear R7000. I've been looking for some help on setting up the router to work well with my chromecast, 2 android phones, 1 android tablet, wii u...
waxensens
- plemansMay 16, 2022Guru - Experienced User
Nothing. Literally 2 dots.
did you need help?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
