Thomaslamf
May 26, 2021Aspirant
Help to Remove DD-WRT Firmware from R700 Nighthawk
Hi, Just after some help to Remove DD-WRT Firmware from R700 Nighthawk, I have tried below but it doesn’t seem to work for me unless I’m doing something wrong help would be much appreciated. Thanks...
Thomaslamf
Ive been trying to register to add a post but, it never works always says the bot code is wrong when its right. plemans
May 27, 2021Guru - Experienced User
Not sure what you expect the netgear forums to do for a ddwrt issue.
Again, use their forums for their firmware. Or your likely to brick your device
