chiner
Dec 16, 2022Follower
Help! Trying to get Nighthawk AX4 AX3000 setup as a primary router.
To start I’m trying to help a friend get his network up and running since his router was stolen by a roommate. He’s using CenturyLink, his router connects via a coax cable. The Netgear Nighthawk does...
Dec 16, 2022Guru - Experienced User
If he has coax coming into the apartment, he'll need a modem that is compatible with her service.
so he needs to contact his ISP to see what modem/gateway is compatible with his service. Once he has that, you connect the router to the modem.
It could be his other device was a modem/router combo device.
