Kekokake
Apr 09, 2020Follower
Help with dmz and portforwarding
I have a problem with my routers. The first router I have did I get from my ISP and its trash in all sorts of ways and then I bought the r7800 in a attempt to get my wifi to work better. Because I hav...
- Apr 09, 2020
DMZ makes everything open. It bypasses firewalls & co so all ports are open. You should port forward on the NG router. Connect your computer(s) to the NG and let the ISP modem/router act as a DMZ pass-through
microchip8
Apr 09, 2020Master
