walter44
Aug 14, 2023Follower
Help with Nighthawk AC1900
Hello all, I am giving a try asking this here. I am facing some issues with my router Nighthawk since a few months ago. Here is some context and what happened: In the place I live, there is free in...
michaelkenward
Aug 14, 2023Guru - Experienced User
walter44 wrote:
In the place I live, there is free internet, I just have to get a router and connect it, and then I used to use the networks that were created by default by the Nighthawk router.
What is tour router? (AC1900 is a wifi speed. not a model number.)
How does it connect to whatever your owner provides? Plugged into something? Connected by wifi?
microchip8 is right in that this is really an issue to take up with the owner, but answer those questions and maybe you can get a better idea of what to ask them.
