kawivukan
Sep 12, 2020Guide
Help with RAX20 and port forwarding FTP
I just got this router today and have it setup through a Xfinity Gateway in bridged mode. Previous to this on the Gateway, I was able to port forward my Raspberry PI FTP server (port 21) and access i...
- Sep 13, 2020
There is only one port 21/TCP ... if the router is configured on ReadyShare to FTP, port 21/TCP is obviously already occupied. Disable the FTP service on the advanced ReadyShare settings.
I would expect that this does free up port 21/TCP on the WAN interface to become available for the port forwarding. Netgear has an old flaw on port 443 (the default https one) - even with the https remote access service and https ReadyShare disabled or relocated to an alternate port, the port 443/TCP isn't becoming available for port forwarding.
Something general ref. ftp: These routers (including your previous one) have an application layer gateway (ALG) listening on the standard ports, e.g. 21/TCP for FTP on the handshake communication for the passive connection, dynamically adding a port forward to that port. If using FTPS (encryption) the ALG can't work so you need to configure the passive port range configured on the ftp server in a port forward range.
kawivukan
Sep 13, 2020Guide
Thank you.I was able to get it sorted out with what you mentionted.
schumaku
Sep 13, 2020Guru - Experienced User
kawivukan wrote:Thank you.I was able to get it sorted out with what you mentionted.
Disabled the FTP on the ReadyShare was sufficient?
Time permitting, if you have the ability to set-up a test e.g. a https on the RasPi (or any other service operating on 443/TCP like telnet for a test), I would like to learn if if the RAX, e.g. your RAX20 does still reserve 443/TCP internally, or of 443/TCP is freely available (if removed from ReadyShare and the remote access). Following the test, do't forget to disable the test service or it's port forward again.
TIA,
-Kurt
