baseballbat's avatar
Sep 28, 2020
Help with Router
So the Internet suddenly stopped working, I reset the Router and Modem, same problem. The Internet light is Red. The Internet is working from the Modem as we connect it directly to laptop. When Rou...
  • plemans's avatar
    Sep 29, 2020
    did parental controls get turned on?
    Or the DNS provider get changed?
    Have you tried a simple factory reset and reinstall?
