baseballbat
Sep 28, 2020Tutor
Help with Router
So the Internet suddenly stopped working, I reset the Router and Modem, same problem. The Internet light is Red. The Internet is working from the Modem as we connect it directly to laptop. When Rou...
- Sep 29, 2020
did parental controls get turned on?
Or the DNS provider get changed?
Have you tried a simple factory reset and reinstall?
Sep 29, 2020Guru - Experienced User
What modem do you have?
What firmware is on the router?
baseballbat
Sep 29, 2020Tutor
Modem is- Netgear Cable modem cm600
Firmware- V1.0.2.54_1.0.56
- plemansSep 29, 2020Guru - Experienced User
do hardwired devices work?
- baseballbatSep 29, 2020TutorYes internet works when connected directly. Also repeating this, but when phone is connected to wifi, Whatsapp, Instagram and Netflix works perfectly fine like normal. But nothing else works in Reddit, browsers and stuff.
