Kimbers
Mar 04, 2021Aspirant
Help with wifi area coverage
Hi All, I have a coverage question and maybe a point towards a solution if you have one! I am having a work office built in my backyard, it is 100 feet away from the house. The current router...
- Mar 05, 2021
30 metres is a bit of a stretch for any technology, wifi or Powerline Ethernet.
I would not expect a R7000 to reach that far. Powerline might work, but if the separate building has its own junction box, there could be some isolation from the house mains.
Something like the expensive outdoor repeater might work.
Orbi RBS50Y - Mesh WiFi Range Extender | NETGEAR
It describes itself as an Orbi satellite, but it can also work with other routers.
Otherwise, plug your needs into this page:
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
michaelkenward
Mar 05, 2021Guru - Experienced User
