shamika18's avatar
shamika18
Follower
Apr 06, 2023
Hey netgear community, have an issue with my wifi speeds.
I just moved to a new apartment, using the same ISP with my equipment that I've had for 4 years. Did not have any issue with my old apartment, managed to get 150Mbps+ down but now at the new place barely 50mbps down within line of sight.
  • FURRYe38's avatar
    Do you have a NG product? If so, please give the model#? R#### or RAX###?
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
  • plemans's avatar
    Are you testing over 2.4ghz or 5ghz?
    Makes a big difference.
    What router is it?
    What wired speeds do you get?
  • michaelkenward's avatar
    michaelkenward
    Did you reset the anonymous Netgear router when you moved?
    When you set up a device it adapts its own settings to match the incoming connection. It may be the same ISP, but they have a habit of tweaking their settings according to the circumstances.
    A simple first move is this:
    How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
    Then set up the thing for the new connection.
