arie52
Oct 10, 2022Aspirant
Hi everyone
I have a problem . I put my Nighthwak R 7000 IN THE BRIDGE MODUS AND MY ROUTER WAS ALSO IN THE BRIGDE MODUS. NOW IT DOES NOT WORK ANYMORE. HOW CAN I GET THE NIGHTHAWK OUT OF THE BRIDGE MODUS? I ...
- Oct 10, 2022
Factory reset it. Push and hold reset for 7-15 seconds while powered on.
Thats probably the fastest/easiest way
Oct 10, 2022Guru - Experienced User
arie52
i will try again but did reset the router
- plemansOct 10, 2022Guru - Experienced User
and what happens when you try to connect to it?
Is it disconnected from the other routers/modems?
Have you checked to see what ip address its assigned to itself? The default is 192.168.1.1 but some will auto switch to the 10.0.0.1
- michaelkenwardOct 11, 2022Guru - Experienced User
After you do this, remember to reboot the network in the expected order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
- arie52Oct 19, 2022Aspirant
thanks everyone i did solve the problem
have a nice day
arie
