PCMeier
May 22, 2019Aspirant
High Bufferbloat, can't find any solutions, have extremely high ping spikes when playing any game
So just recently ive been getting extremely high ping spikes extremely frequently. This occurs in every game i play and makes it unplayable. I have done speed tests and my upload and download spe...
- Jun 14, 2019
I have found a solution that will work.
My solution was buying a wall adapter ethernet connection.
I found mine on amazon.
IrvSp
May 23, 2019Master
Well, you gave no real info?
First question I'd ask is HOW do you know this AND why do you think this is a router problem?
I ask because BUFFER BLOAT can be caused by the MODEM!!! Especially if it has a PUMA 6 chipset. So to rule out the Router, CHECK this list and see if your modem is on it, https://approvedmodemlist.com/intel-puma-6-modem-list-chipset-defects/. If you are a Spectrum customer, you probably have one of the Arris Tx16xx modems. Good luck getting that exchanged... I had a hard time doing that.
