PCMeier
May 22, 2019Aspirant
High Bufferbloat, can't find any solutions, have extremely high ping spikes when playing any game
So just recently ive been getting extremely high ping spikes extremely frequently. This occurs in every game i play and makes it unplayable. I have done speed tests and my upload and download spe...
- Jun 14, 2019
I have found a solution that will work.
My solution was buying a wall adapter ethernet connection.
I found mine on amazon.
PCMeier
May 23, 2019Aspirant
i have done the dslreport.com speed tests
IrvSp
May 23, 2019Master
PCMeier wrote:i have done the dslreport.com speed tests
and your Buffer Bloat is what?
What is your LATENCY? BB usually has it over 50.
Did you use THIS tool, http://www.dslreports.com/tools/puma6?
- PCMeierJun 05, 2019Aspirant
So, I finally got my new modem and the problem still remains, i bought a new wifi chip for my computer and that didnt help. When i check my internet speed at dslreports.com, I get around 100 megabits download, around 1 megabit upload(which has also been happening since this problem arose) and my bufferbloat is in the 200-1000, if it even tests its. Occasionally, it will say latency too high to test. The wifi chip i bought was a Netgear A7000 usb adabter. I have also checked the connection to servers in game and am getting ping spikes and packet loss
- IrvSpJun 06, 2019Master
What is the modem you got? Did the ISP approve it and configure it on their backend?
Can you test with a wired connection?
- PCMeierJun 06, 2019Aspirant
The modem I recently got was a technicolor dpc3216 that the ISP(Spectrum) gave to me when I asked for my modem to be replaced. They did not configure the modem, im assuming configure means the same thing as install, I installed the modem. I cant get a wired connection due to my desktop being to far away from the modem and router.
