kingjetty
Nov 13, 2020Aspirant
High ping fast WiFi on my R8000p router
So I’ve been experiencing high ping on my game and I cannot seem to find out why I live close to the game servers and I still get high ping I always use to get 10-20 ping now I get 60-100 ping and it ...
- Nov 13, 2020
The Arrris DG1670A is a modem/router combo device. It isn't just a modem.
It causes a double nat and can increase ping times.
https://kb.netgear.com/30186/What-is-Double-NAT
Nov 13, 2020Guru - Experienced User
theres been plenty of articles written on decreasing ping times so I won't re-write them.
https://www.cnet.com/how-to/heres-how-to-get-lower-ping-for-online-gaming/
What firmware is on your router?
What modem is it connected to?
Do you ping times stay roughly the same if you connect your gaming device directly to the modem?
- kingjettyNov 13, 2020AspirantMy router connected to an cable one arris modem
And I updated the firmware to the newest one V1.4.1.64_1.3.25- plemansNov 13, 2020Guru - Experienced User
And I updated the firmware to the newest one V1.4.1.64_1.3.25Arris makes a lot of modems. Which one?
Did the ping increase after the firmware upgrade?
Or when did it change?
- kingjettyNov 13, 2020AspirantIt’s the Arris DG1670A DOCSIS 3.0 modem the ping did not increase after the upgrade no
