kingjetty
Nov 13, 2020Aspirant
High ping fast WiFi on my R8000p router
So I’ve been experiencing high ping on my game and I cannot seem to find out why I live close to the game servers and I still get high ping I always use to get 10-20 ping now I get 60-100 ping and it ...
- Nov 13, 2020
The Arrris DG1670A is a modem/router combo device. It isn't just a modem.
It causes a double nat and can increase ping times.
https://kb.netgear.com/30186/What-is-Double-NAT
Nov 13, 2020Guru - Experienced User
theres been plenty of articles written on decreasing ping times so I won't re-write them.
https://www.cnet.com/how-to/heres-how-to-get-lower-ping-for-online-gaming/
What firmware is on your router?
What modem is it connected to?
Do you ping times stay roughly the same if you connect your gaming device directly to the modem?
kingjetty
My router connected to an cable one arris modem
And I updated the firmware to the newest one V1.4.1.64_1.3.25
- plemansNov 13, 2020Guru - Experienced User
And I updated the firmware to the newest one V1.4.1.64_1.3.25Arris makes a lot of modems. Which one?
Did the ping increase after the firmware upgrade?
Or when did it change?
- kingjettyNov 13, 2020AspirantIt’s the Arris DG1670A DOCSIS 3.0 modem the ping did not increase after the upgrade no
