kingjetty
Nov 13, 2020Aspirant
High ping fast WiFi on my R8000p router
So I’ve been experiencing high ping on my game and I cannot seem to find out why I live close to the game servers and I still get high ping I always use to get 10-20 ping now I get 60-100 ping and it ...
- Nov 13, 2020
The Arrris DG1670A is a modem/router combo device. It isn't just a modem.
It causes a double nat and can increase ping times.
https://kb.netgear.com/30186/What-is-Double-NAT
kingjetty
Nov 14, 2020Aspirant
Well my question is how do I disconnect it I need more instruction that link had poor instructions
Nov 15, 2020Guru - Experienced User
How do you disconnect it?
Disconnect what?
Put the dg1670a in bridge mode? You'd want to contact Arris or your isp to assist you with that.
- kingjettyNov 19, 2020AspirantHow will putting it into bridge mode help how
- plemansNov 19, 2020Guru - Experienced User
you asked that question. And I answered it.
- kingjettyNov 30, 2020AspirantSo i can’t put I’m my router into bridge mode because I have other family member using WiFi and it’s not then causing high latency for me could their be other nighthawk routers interfering with mine causing high latency
